Andreas,
Channel access
does not hard code the subnet mask. It obtains the
broadcast
address by
querying all of the network interface cards during initialization
and
asking for the
broadcast address that was configured for the network
interface.
The address
range 192.168.10.n is in a class C network. Therefore, the subnet
mask
0xffff0000 can not
be used. Instead it must be 0xffffff00 or some more restrictive subnet
mask with
more least
significant
bits set.
I am surprised that
the Linux machine has allowed its net mask to be set to
0xffff0000
when it is in this
IP address range. You will probably need to configure the Linux box so
that its
network
interface is properly configured for your network.
Jeff
PS:
To avoid subnetting
annoyances on our project we placed our controls
network behind a
firewall with network address translation (NAT) capabilities, and
allocated an entire class B network for our control system from
the address
ranges which are
reserved for private internets. There are 64,000
host IP addresses in a class B network.
PPS:
Configuring
different subnet masks on the same network frequently results
in
ICMP storms which
can impact the performance of broadcast based
communication.
-----Original Message----- From:
[email protected] [mailto:[email protected]] Sent:
Wednesday, October 20, 1999 1:20 PM To: Andrew Johnson; Bob Dalesio;
tech-talk Subject: Re: no channel access to IOC
Hi
Andrew, hi Bob, actually I tried to set the netmask this way to :ffff0000,
but the UDP of the IOC was still the same 192.168.10.255... Is the
subnetmask somehow hardcoded in channel access? As I pointed out, the netmask
is arbitrary in this system, because it consist only of one (or two) PCs and
one IOC, no connection to the outer world. So we tried both, to set it to a
B-class subnet or to a C-class subnet on both machines. None of this worked.
I will try it again tomorrow, maybe we missed something. Do you have a
link to the debugging tools at LANL, the link to the LANL site from http://www.cebaf.gov/accel/documents/epics_doc.html
is not valid anymore (requires authentication).
Thanks, - Andreas
Hi Andreas,
Are the net masks the same? Look at the debugging IOC slides on
the LANL web site for finding the netmask - if you need to.
Bob
Andrew Johnson wrote:
Hi Andreas,
Luedeke Andreas wrote: > > [...] linboot.ioc.1066 >
192.168.255.255.5064: udp 32 (ttl 64, id [...]) ... > [...]
iocLin.ioc.1031 > 192.168.10.255.5065: udp 16 (ttl 30, id [...])
These are broadcast addresses on two different subnets which is usually
why they can't communicate - you either need to set their subnet masks
to be the same on both machines, or if your network topology won't allow
this you'll need to set the EPICS_CA_ADDR_LIST environment variable to
the broadcast address of the other subnet (see the Channel Access
reference manual for details). On an ioc use putEnv("VAR=value")
to set this any time before iocInit.
You can see the subnet mask by using ifShow at the vxWorks shell, and set
it by adding ":ffffff00" (without the quotes) after the target's IP
address in its boot parameters. Replace the ffffff00 with whatever
the mask should be for its subnet.
- Andrew -- Complexity comes for free, Simplicity you have to
work for. --
Andreas Luedeke, Controls Group, Swiss-Light-Source, PSI
mailto:[email protected], tel:+41-(0)56-310-4002, fax:-3351
- Re: no channel access to IOC Luedeke Andreas
<1999>
2025
2026
<1999>
2025
2026
