1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: bumpless reboot
To: [email protected]
Date: Tue, 26 Oct 1999 10:24:22 +0200 (MET DST)
 	Hello,
 	I try to use the "bumpless reboot" software available in the "Compatible
Software" part of EPICS ANL server. I am running 3.13.1 on MVME2400. I compile
on Solaris7.
1. I have the following errors in compiling dbrestore.c :
../dbrestore.c:95: `DBF_GBLCHOICE' undeclared (first use this function)
../dbrestore.c:96: `DBF_CVTCHOICE' undeclared (first use this function)
../dbrestore.c:97: `DBF_RECCHOICE' undeclared (first use this function)
	etc ....
2. I tried to run "save_restore" (which compiles correctly) with the following:
-> save_restore_debug=1
save_restore_debug = 0x1b94c58: value = 1 = 0x1
-> cd "/dir/ioc/autoSave"
value = 0 = 0x0
-> create_monitor_set("/dir/ioc/autoSave/chf.req", 10.0)
With fdblist, it seems verything is OK :
-> fdblist
fdblist
/dir/ioc/autoSave/chf.req:
  last saved file -
  method c period 240 trigger chan ÿ monitor period 600
  0 channels not connected - or failed gets
        CHFCH9_mbbo     Out    0
        CHFCH8_mbbo     Out    0
        CHFCH7_mbbo     Out    0
        CHFCH6_mbbo     Out    0
        CHFCH5_mbbo     Out    0
        CHFCH4_mbbo     Out    0
        CHFCH3_mbbo     Out    0
        CHFCH2_mbbo     Out    0
        CHFCH1_mbbo     Out    0
value = 0 = 0x0
I have the following related processes running :
EV save_resevent_task    1a0e410 189 PEND         16250c  1a0e378   3006b     0
save_restorsave_restore  1a18d38 190 PEND+T       16250c  1a18c48  3d0004     2
But, whatever change I made on the CHF...mbbo records, nothing happens (no file
written, no debug trace , no change in the fdblist trace).
Do I miss something ????
Thanks in advance,
	Jean-Francois
                                |  Jean-Francois Gournay               |
                                |  DAPNIA/SIG                          |
                                |  CEA-Saclay                          |
                                |  F-91191 Gif-Sur-Yvette CEDEX        |
                                |  Phone : +33 (0)169087032            |
                                |  Fax   : +33 (0)169086301            |
                                |  E-Mail:  [email protected]            |
Prev: RE: Daylight Savings Time and the CA Server Jeff Hill
Next: Oracle for archiving Burkhard W. Kolb
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: bumpless reboot Tim Mooney
