1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tsTextToStamp y2k glitch
To: "Christopher A. Larrieu" <[email protected]>
Cc: [email protected]
Date: Wed, 27 Oct 1999 08:06:00 -0500
"Christopher A. Larrieu" wrote:
> Hi all,
>   I've discovered a minor problem in tsTextToStamp() which
> prevents the year "00" from being parsed properly, while
> 01..89 are problem-free.  The culprit is a test for
> (year <= 0), which should be (year < 0).  To wit, the
> following modification should be made to tsSubr.c version
> 1.35.2.1 at lines 1318 and 1368.
> line 1318:
>     if (count <= 1 || t.year <= 0)
>   becomes
>     if (count <= 1 || t.year < 0 ||
>         (count > 3 && t.year < TS_EPOCH_YEAR))
>   I vaguely recall someone else mentioning something similar
> some time ago, so sorry if this is already known.  As far as
> I can tell, none of EPICS base uses this routine, though I
> haven't checked the extensions.
I made the change so that it will be in both the next patch release (3.13.2) and
in the 3.14 releases.
Marty Kraimer
tsTextToStamp y2k glitch Christopher A. Larrieu
Prev: tsTextToStamp y2k glitch Christopher A. Larrieu
Next: ni gpib Marty Kraimer
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
