1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: database limits
To: [email protected]
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 Nov 1999 17:29:17 +0100 (MET)
>>>>> Burkhard Kolb writes:
  > Hi, can anybody remind me where to find the documenation about the
  > changes to the standard vxworks distribution for Epics?  Where do I
  > find the tuning parameters to increase the allowed size of a
  > database?
There is no such limit in database size. Even if there was, it would be
inside EPICS base, not inside the vxworks patches.
  > Problem: I have an MVME162 with a CANbus interface which controls
  > several Wiener fantrays. When increasing the number of crates I
  > suddenly get errors during dbloadrecords. The records are all
  > generated by the same templates, so I know they are correct.
What kind of errors?
What kind of MVME162?
Which version of vxWorks?
Which version of the BSP?
Which version of EPICS base?
You may be running into memory limits because the standard BSP for the
mv162 does not auto-detect the board's memory size and the factory
default is 1MB, iirc. The APS vxWorks patches include a fix for this
problem.
See http://epics.aps.anl.gov/xfd/SoftDist/vxworks.htm for details about
how to obtain the APS vxWorks patches.
Hope this helps,
Ralph
Re: database limits Burkhard Kolb
Prev: database limits Burkhard Kolb
Next: Re: database limits Dennis M Reichhold
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: database limits Burkhard Kolb
