1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: replacing the default CA exception handler
To: Jeff Hill <[email protected]>
Cc: EPICS-tech-talk <[email protected]>
Date: Fri, 19 Nov 1999 13:33:00 -0600
Jeff Hill wrote:
> Perhaps I should just have a call in the CA client library -
> ca_disable_exeception_aborts() - so that the default exception
> handler can be used.
I vote for this.
> Changing topics:
> Persons developing CA client applications have asked for the
> capability to replace the function that gets called when CA prints
> a diagnostic message so messages don't go to stderr and they go to
> some log file instead. This capability was provided in
> the form of ca_replace_printf_handler().
> Perhaps Marty will get the same request with
> errlogPrintf() when it is used more often in standalone applications.
> If this functionality is added then I can base the client lib on
> errlogPrintf() while remaining backwards compatible with
> ca_replace_printf_handler()? If so I could eliminate some
> redundant code and reduce interdependency between the
> client and server libraries.
This sound like a good idea BUT.
errlogPrintf is actually a family of routines and currently have completely
different implementation of the host and of the ioc.
On the host it would be possibly to just provide a call
errlogReplaceVprintf(...)
This would work fine. BUT is this really needed. Maybe the answer is yes.
On the ioc an errlog call transfers a message to another task. This other task
already supports errlogAddListener. If no listeners are attached nothing is
displayed. Base currently base supplies iocLogClient which calls
errlogAddListener. iocLogClient passes the messages to a logServer. Other code
can also call errlogAddListener. For example CDEV provides code that calls
errlogAddListener and passes the messages to the CDEV error log server. errlog
on the iocs also provides a shell callable switch that decides if messages
should also be displayed via printf. Thus for the ioc version of errlog I
maintain that no additional flexability is required.
Marty Kraimer
RE: replacing the default CA exception handler Jeff Hill
Prev: RE: replacing the default CA exception handler Jeff Hill
Next: empty channel field in medm/dm2k Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
