1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How to use mbboDirect ?
To: [email protected]
Date: Fri, 26 Nov 1999 16:16:25 +0100
Hi all,
can someone tell me the correct way to set all outputs of a mbboDirect
record ?
- I can set fields .B0 - .BF :
    dbpf "xvme220:mbboDirect0.B0","1"
    DBR_UCHAR:          1         0x1
    value = 0 = 0x0
    -> dbgf  "xvme220:mbboDirect0.B0"
    DBR_UCHAR:          1         0x1
    value = 0 = 0x0
also I can get the VAL field :
    -> dbgf  "xvme220:mbboDirect0"
    DBR_USHORT:         1         0x1
    value = 0 = 0x0
but I want to set all outputs in one operation. I get the following
response when I try the obvious :
    -> dbpf "xvme220:mbboDirect0","1"
    value = 32833541 = 0x1f50005
    -> filename="../recGbl.c" line number=87
    Attempt to modify noMod field PV: xvme220:mbboDirect0.VAL error
detected in rout
    filename="../dbTest.c" line number=358
    Attempt to modify noMod field dbPutField error
The record ref manual (3.13) p173 states "VAL can be changed via dbPuts
at run time when OMSL is supervisory" - (which it is).
The 3.13 record ref manual is inconsistant with the doc on the cebaf ftp
site -
the cebaf doc (probably 3.12) defines VAL as a USHORT, the 3.13 doc
defines VAL as a ENUM,
and my .dbd file also defines VAL as a USHORT.
I am runing 3.13b12
-> dbpr "xvme220:mbboDirect0",4
ACKS: NO_ALARM      ACKT: YES           ASG:                ASP:
0x00000000
B0: 1               B1: 0               B2: 0               B3: 0
B4: 0               B5: 0               B6: 0               B7: 0
B8: 0               B9: 0               BA: 0               BB: 0
BC: 0               BD: 0               BE: 0               BF: 0
BKPT: 0x00          DESC: xvme220       DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DOL:CONSTANT        DPVT:
0x00000000
DSET: 0x01bb7080    DTYP: XVME-220      EVNT: 0
FLNK:CONSTANT 0
IVOA: Continue normally                 IVOV: 0             LALM: 0
LCNT: 0             LSET: 0x01aa0720    MASK: 255
MLIS: 0x000000000000000000000000        MLOK: 0x01ba6d4000000000
MLST: 1             NAME: xvme220:mbboDirect0               NOBT: 8
NSEV: NO_ALARM      NSTA: NO_ALARM      OMSL: supervisory   ORAW: 1
ORBV: 1             OUT:VME_IO #C0 S0 @ PACT: 0             PHAS: 0
PINI: YES           PPN: 0x00000000     PPNN: 0x00000000    PRIO: LOW
PROC: 0             PUTF: 0             RBV: 1              RDES:
0x01abd170
RPRO: 0             RSET: 0x01ae9274    RVAL: 1             SCAN:
Passive
SDIS:CONSTANT       SEVR: NO_ALARM      SHFT: 0
SIML:CONSTANT
SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT       SPVT:
0x00000000
STAT: NO_ALARM      TIME: 0x0000016339a175f9                TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 1              VAL: 1
value = 0 = 0x0
here is the .db file :
record(mbboDirect,"xvme220:mbboDirect0") {
        field(DESC,"xvme220 ")
        field(DTYP,"XVME-220")
        field(OUT,"#C0 S0 @")
        field(NOBT,"8")
        field(PINI,"YES")
what am I doing wrong ??????
Steve
Re: How to use mbboDirect ? Ralph . Lange
Prev: Re: How to use mbboDirect ? Ralph . Lange
Next: Re: How to use mbboDirect ? Steve Hunt
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV's on the www Arne Freyberger
Next: Re: How to use mbboDirect ? Ralph . Lange
