1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Client library
To: Eric Boucher <[email protected]>, [email protected]
Date: Mon, 29 Nov 1999 11:57:15 -0500
Eric,
  I've partially implemented a C++ wrapper around CA which
runs the CA client code in a separate thread in order to hide
the asynchronous "untidy bits" (passing control off to to the
CA library to handle callbacks, etc.) from the user, though
have not yet had the opportunity to test it.  The one major
immediately discernable issue is how to communicate between
the threads without ultimately falling back to a polling loop
inside the CA thread.
  My solution to this was the following:
  (1) set up a callback for getting CA's fd's
  (2) create a special fd.  Call it fd_foo
  (3) within the CA thread, select on all of CA's
      file descriptors, as well as fd_foo
  (4) when select returns, check to see if the active
      file descriptor is fd_foo.
        + If so, then do whatever
          CA stuff you want (e.g. add a monitor, unconnect
          a chid, etc.).
        + If not, then pass off control to CA so that
          it can do whatever work needs doing on the active
          file descriptor.
  (5) select again within the CA thread.
  The whole point of this is to ensure that CA is in a stable
state before calling any of the client code.  When a thread wants
to perform some CA task, it writes to fd_foo its thread ID, which
causes select() to return in the CA thread, which then yields
to the thread which initiated the whole sequence of events.
  Unfortunately, I'm not the one to say authoritatively whether
or not this is the best approach, but hought I would at least
share the idea with you.
  Best Regards,
Chris
Christopher A. Larrieu
Jefferson Laboratory
(757) 269-5097
Channel Access Client library Eric Boucher
Prev: RE: Channel Access Client library Jeff Hill
Next: invitation to new discussion of java GUI's Chip Watson
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
