1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: zombie problem at UNIX IOC
To: [email protected]
Date: Wed, 8 Dec 1999 19:43:24 +0600 (NSK)
Dear Sir/Madam,
I have zombie problem at UNIX IOC.
Pthread is analog of VxWorks task. When IOC receives the request for
operating with PV,  iocCore spawns the pthreads: "CA event", "CA client".
Which is completed by "exit()" call or "return ()", this operation
switches pthread in  zombie state. iocCore contains following list of
pthreads:
__01.)_____tid=51___name=taskwd____PRI=4.
__02.)_____tid=54___name=cbLow____PRI=16.
__03.)_____tid=62___name=cbMedium____PRI=16.
__04.)_____tid=56___name=cbHigh____PRI=16.
__05.)_____tid=36___name=dbCaLink____PRI=15.
__06.)_____tid=78___name=ts_Casync____PRI=16.
__07.)_____tid=48___name=scanOnce____PRI=16.
__08.)_____tid=77___name=scan1000____PRI=16.
__09.)_____tid=50___name=scan500____PRI=15.
__10.)_____tid=55___name=scan200____PRI=14.
__11.)_____tid=53___name=scan100____PRI=13.
__12.)_____tid=49___name=scan50____PRI=12.
__13.)_____tid=31___name=scan20____PRI=11.
__14.)_____tid=32___name=scan10____PRI=10.
__15.)_____tid=67___name=CA TCP____PRI=13.
__16.)_____tid=66___name=CA UDP____PRI=10.
__17.)_____tid=37___name=CA online____PRI=10.
__18.)_____tid=68___name=CA client____PRI=12.
__19.)_____tid=76___name=CA event____PRI=11.
__20.)_____tid=75___name=CA client____PRI=12.
__21.)_____tid=74___name=CA event____PRI=11.
__22.)_____tid=73___name=CA client____PRI=12.
__23.)_____tid=72___name=CA event____PRI=11.
__24.)_____tid=71___name=CA client____PRI=12.
__25.)_____tid=70___name=CA event____PRI=11.
__26.)_____tid=69___name=CA client____PRI=12.
__27.)_____tid=38___name=CA event____PRI=11.
__28.)_____tid=57___name=CA client____PRI=12.
__29.)_____tid=64___name=CA event____PRI=11.
__30.)_____tid=63___name=CA client____PRI=12.
__31.)_____tid=59___name=CA event____PRI=11.
__32.)_____tid=65___name=CA client____PRI=12.
__33.)_____tid=58___name=CA event____PRI=11.
__34.)_____tid=79___name=CA client____PRI=12.
__35.)_____tid=80___name=CA event____PRI=11.
__36.)_____tid=81___name=CA client____PRI=12.
__37.)_____tid=82___name=CA event____PRI=11.
__38.)_____tid=83___name=CA client____PRI=12.
But all threads("CA event","CA client") from iocCore has zombie state.
Would you help me do this problem?
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev  11
630090, Novosibirsk, RUSSIA
fax     +7 3832 342163
phone   +7 3832 394977
RE: zombie problem at UNIX IOC Jeff Hill
Re: zombie problem at UNIX IOC john sinclair
Prev: "Simultaneous" multi-device control Ron Chestnut
Next: Delays in receipt of CA monitors Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: zombie problem at UNIX IOC Jeff Hill
