1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Delays in receipt of CA monitors
To: john sinclair <[email protected]>
Cc: [email protected]
Date: Fri, 10 Dec 1999 10:38:56 -0700
john sinclair wrote:
John,
You bring up an interesting issue, but... Our problem is not that the
heartbeats are dropped, but are just delayed. The heartbeat timestamps
generated by record processing are always exactly 0.5 second apart so we
are recieving all of them in sequence.
Peregrine
> This came to me right after sending the previous message.
> If channel access flow control is the problem, then a seqence number
> rather that a 0 to 1 toggle could fix things. The watchdog would get reset
> whenever the number changes.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
Peregrine M. McGehee	Coordinator, Los Alamos Astrophysics
(505) 667-3273 		MS H820, LANL, Los Alamos, NM 87545
Re: Delays in receipt of CA monitors john sinclair
Prev: Re: CA monitors...Update #2 Garrett D. Rinehart
Next: RE: Delays in receipt of CA monitors Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Delays in receipt of CA monitors john sinclair
Next: RE: replacing the default CA exception handler Jeff Hill
