Dear Mr. Sinclair,
I am very thankful to you for your e-mails.
My apologies to you for delay of answer (11-13 Dec. is holidays in
Russia).
I solved problem of zombie threads by following way:
"taskSpawn()" executes pthread-detach() call before return().
You can get LynxOS EPICS codes by ftp
sky.inp.nsk.su
user: salikova
passwd: tansalik
epics_LynxOS.x86.tar.gz (It has size 7.9Mb)
As I wrote, Now I test IOC codes.
At N-th reading of PV "caExample" has next bug.
root:aiExample1 7.000000
FELsparc> caExample root:aiExample1
root:aiExample1 9.000000
root:aiExample1 0.000000
root:aiExample1 1.000000
root:aiExample1 3.000000
CA.Client.Diagnostic..............................................
Message: "User specified timeout on IO operation expired"
Severity: "Warning" Context: "ca_pend_io failure"
Source File: ../caExample.c Line Number: 20
Message: "The request was ignored because the specified channel is
disconnected"
Severity: "Error" Context: "ca_get failure"
Source File: ../caExample.c Line Number: 21
Abort (core dumped)
I shall be grateful if you inform me about your opinion of this bug.
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev 11
630090, Novosibirsk, RUSSIA
fax +7 3832 342163
phone +7 3832 394977
On Fri, 10 Dec 1999, john sinclair wrote:
> On Wed, 8 Dec 1999, Tatiana V. Salikova wrote:
> > Dear Sir/Madam,
> > I have zombie problem at UNIX IOC.
> > Pthread is analog of VxWorks task. When IOC receives the request for
> > operating with PV, iocCore spawns the pthreads: "CA event", "CA client".
> > Which is completed by "exit()" call or "return ()", this operation
> > switches pthread in zombie state. iocCore contains following list of
> > pthreads:
> As mentioned by Jeff, zombie threads are threads that have exited
> for which the parent has not called pthread_join. One way to prevent
> this is for the parent to call pthread_detach for each child thread.
> Does this work for all pthread implementations? I don't know.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
- RE: zombie problem at UNIX IOC Jeff Hill
- Re: zombie problem at UNIX IOC john sinclair
CA monitors... Garrett D. Rinehart
RE: CA monitors... Jeff Hill
<1999>
2025
2026
<1999>
2025
2026
