1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: event_handler_args
To: [email protected]
Date: Thu, 20 Jan 2000 16:04:21 -0500
Am I correct in thinking that the DBR structure pointed to by the
event_handler_args structure returned in the callback for a monitored channel
should be treated as volatile, requiring the data in it to be copied if you
want to use it outside of the scope of the callback function ?
Brian McAllister                 Application Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
RE: event_handler_args Jeff Hill
Prev: ARR not Y2K ready - fix ? Brian McAllister
Next: RE: event_handler_args Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
