1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: alh CA Disconnects
To: <[email protected]>
Date: Fri, 21 Jan 2000 08:17:45 -0500
I have been trying to use alh and am getting sporadic (every 2-3 hours) CA
disconnect of groups of records.  The alh config file has records in two
IOC's.  When a disconnect occurs,  all records attached to an IOC disconnect
and then reconnect the next second.  This happens to both IOC but not at the
same time.
The system is lightly loaded.  The TMO variable is 30 seconds and the BEACON
is 15 seconds.  medm clients and other CA clients on the host do not
disconnect.  This behavior been the case with the latest alh(1.1.2) and a
former version.
The error message I get is shown below (one message for each
mass-disconnect, not one for each record).  The transient PV alarm states
are  COMM and INVALID,  and then back to NO_ALARM again the next second.
Using R3.13.0beta11, mv177 IOC, solaris Host.  "Private" network.  Any
clues?
alCaException: Channel Access Exception:
  Channel Name: Unavailable
  Native Type: Unavailable
  Native Count: 0
  Access: Unavailable
  IOC: Unavailable
  Message: Network connection lost
  Context: ioc_src1
  Requested Type: TYPENOTCONN
  Requested Count: 0
  Source File: ../iocinf.c
  Line number: 1422
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
Re: alh CA Disconnects Marty Kraimer
EpicsR3.13.1 CA build Zoltan Kakucs
Re: EpicsR3.13.1 CA build Janet Anderson
Prev: RE: event_handler_args Jeff Hill
Next: Re: alh CA Disconnects Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EpicsR3.13.1 CA build Janet Anderson
