1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Data Fanouts
Cc: [email protected]
Date: Fri, 21 Jan 2000 17:41:35 -0500
Mark:
Your suggestions were helpful. I made the link from FLNK to PROC, but that by
itself was not enough. I also tried adding a link from OUTx to the VAL of the
next Dfanout and that got me closer.
The final solution (for a total of 3 fanouts) was the FLNK to PROC link (1 -->
2, 2 --> 3) AND making the DOL field in all three Dfanouts the same. Note that
for all three Dfanouts, the OMSL field was set to closed loop. Also, since I
didn't need to waste an OUTx on data propagation, I now had eight OUTx on each
fan. For my purposes, this meant I only needed two fanouts.
Mark Rivers wrote:
> > The Data Fanout record is "similar" to the Fanout. Where as the Fanout record
> > only supports control links (i.e. no data is passed), the Data Fanout propagates
> > control AND data. A Data Fanout record supports eight output links. Can the Data
> > Fanout record also be chained, like the Fanout? If so, could someone explain
> > how? I have tried every permutation I can thank of, linking various types of
> > records with the Data Fanout, to no avail.
> I simply connect the forward link of the first Data Fanout to the .PROC field
> of the second Data Fanout:
> grecord(ddfanout,"$(P)ReadAll") {
>         field(SCAN,"5 second")
>         field(DISV,"0")
>         field(SDIS,"$(P)Acquiring NPP NMS")
>         field(VAL, "1")
>         field(OUTA,"$(P)mca1.READ  PP MS")
>         field(OUTB,"$(P)mca2.READ  PP MS")
>         field(OUTC,"$(P)mca3.READ  PP MS")
>         field(OUTD,"$(P)mca4.READ  PP MS")
>         field(OUTE,"$(P)mca5.READ  PP MS")
>         field(OUTF,"$(P)mca6.READ  PP MS")
>         field(OUTG,"$(P)mca7.READ  PP MS")
>         field(OUTH,"$(P)mca8.READ  PP MS")
>         field(FLNK,"$(P)ReadAll1.PROC")
> grecord(ddfanout,"$(P)ReadAll1") {
>         field(VAL, "1")
>         field(OUTA,"$(P)mca9.READ  PP MS")
>         field(OUTB,"$(P)mca10.READ  PP MS")
>         field(OUTC,"$(P)mca11.READ  PP MS")
>         field(OUTD,"$(P)mca12.READ  PP MS")
>         field(OUTE,"$(P)mca13.READ  PP MS")
> Note that I am using the "ddfanout" record rather than the "dfanout".  The
> "dfanout" documentation in the Record Reference Manual claims that its data
> output is a double.  However, this is not true, it is actually a long.  I
> needed to fan out a double, so I wrote a new record, ddfanout, which simply
> has a double datatype rather than a long.
> Mark Rivers
begin:vcard
adr;dom:;;P.O. Box 846;Middleton;MA;01949;
n:Page;Russell
x-mozilla-html:FALSE
org:MIT -- Bates Linear Accelerator Center
version:2.1
email;internet:[email protected]
title:SW Engineer / Controls & Instrumentation
tel;fax:(617)  253-9799
tel;home:(978)  682-1964
tel;work:(617)  253-9585
x-mozilla-cpt:;0
fn:Page, Russell
end:vcard
RE: Data Fanouts Mark Rivers
Prev: RE: Data Fanouts Mark Rivers
Next: Re: Python/CA Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
