1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using EPICS CA from Python
To: tech-talk <[email protected]>
Cc: Fritz Bartlett <[email protected]>, Stu Fuess <[email protected]>
Date: Thu, 03 Feb 2000 13:51:05 -0600
I have followed the recent postings on using CA from Python with
interest.  We here at Fermilab make extensive use of our version of a
Python/CA interface.  You can get the source and documentation from
http://www-d0.fnal.gov/~savage/caPython/caPython.html
Along with the source code I have included Python modules for Linux,
IRIX, and OSF1.  The wrapper class, CaChannel, is pure Python and will
also run on all these platforms.
Highlights:
+ Straight conversion between C functions and Python functions using
SWIG.  This let's you program in Python as if you were programming in
C.  Some of the more advanced functions have not been implemented due to
constraints with how callbacks are handled.  I haven't completed the
scan group functionality as we don't use it here.
+ Included is a Python class that wraps the functions.  This makes CA in
Python easier to use.
+ Many macros from db_access.h and cadef.h are included along with the
data type identifiers (DBR_XXXX and DBF_XXXX).
Unfortunately we have not had the time to evaluate the CA/Python
interfaces developed by Noboru Yamamoto and Matthieu Bec.  Maybe we can
combine the strongest parts from each project into a standard CA/Python
interface.
Please contact me with any questions or concerns.
Geoff
Re: Using EPICS CA from Python Noboru Yamamoto
Prev: Re: VxWorks global variable device support (capfast can default DOL to not set) William Lupton
Next: Re: VxWorks global variable device support (boRecord.c) saa
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Using EPICS CA from Python Noboru Yamamoto
