1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DEC Threads
To: "J. Frederick Bartlett ([email protected])" <[email protected]>, "Eric Bjorklund" <[email protected]>, "Stephanie Allison" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Fri, 11 Feb 2000 12:52:13 -0700
Hello,
It would greatly simplify my job if I could count on the
availability of threads on all OS that we use. At this
point VMS is the only system with unresolved questions.
I understand that in VMS systems today all access to sockets,
whether Multinet is installed or not, goes through the DEC
socket library. I have been poking around in the VMS doc on the
web and I am not certain that the DEC socket library is thread
safe. It appears that it is not safe to call a socket routine
from an AST, but this is really not the same thing as calling
from two threads. I have similar worries about the ANSI C library
and other fundamental interfaces. If threads are an option then
I also need to know what OS and layered package versions must be
used prior to asking about the impact of this on the mail list.
Do any of you know a VMS GURU who (perhaps yourself) that can
answer these questions, or perhaps someone could call tech support
at DEC (now COMPAQ) or at multinet's TGV (now CISCO).
Jeff
> -----Original Message-----
> From: J. Frederick Bartlett ([email protected])
> [mailto:[email protected]]
> Sent: Wednesday, December 01, 1999 2:52 PM
> To: Jeff Hill
> Cc: EPICS-tech-talk; [email protected]
> Subject: Re: DEC Threads
> Jeff,
>   Yes, DEC threads is a real thread-supporting package with a rich
> assortment of synchronization mechanisms. The early version of this,
> which is probably what your documentation describes, was a prototype
> for what became POSIX threads (POSIX.4A) or pthreads. Unfortunately,
> The DEC threads package was superior, in many ways, to pthreads. Your
> document should also describe the early version of pthreads as well.
>   Most platforms provide an implementation of pthreads and that,
> probably, is the best choice of a threading package if you want
> maximum portability. Depending upon the implementation, the threads
> may not be known to the OS (user-space), known to the OS kernel
> (kernel-space), or somewhere in between. One of the deficiencies of
> pthreads is that it does not offer a recursive mutex; so, if the same
> thread tries to lock a mutex more than once, as might occur when
> library packages are used, the thread becomes permanently blocked. It
> is possible, however, to create a recursive lock using the pthreads
> routines.
>   An alternative to pthreads is ACE that, although it is principally a
> high-level message-passing package, has thread support included.  It
> works on many platforms although the installation is not trivial and
> the size is daunting.  It is probably possible to remove the thread
> support and use it without all of the other, memory overhead. As I
> recall, ACE uses pthreads on many of the supported platforms.
>   For an introduction to the topic, you might start with one of the
> O'Reilly & Associates books, "Pthreads Programming", by Nichols,
> Buttlar, and Farrell. A superior book is "Programming with Threads" by
> Kleiman, Shah, and Smaalders published by Prentice-Hall.
> 						Fritz
Prev: RE: monitors for arrays Eric Bjorklund, NPSM
Next: Specific (VMS) Portability Concerns Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
