X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 21
Dear all,
I believe that I have fixed the "sequencer deletion via 'td'" problem in
the unbundled sequencer. I had introduced it a couple of years back (so
the problem that I have fixed is _not_ present in the EPICS base version
of the sequencer).
I have created a new v1.9.5 of the sequencer. Please refer to the following
URL for details on where to download it.
http://www2.keck.hawaii.edu:3636/realpublic/epics/seq
I would like to know of people who are using v1.9.4 and v1.9.5 operationally.
So far, I am only of aware of SLAC as users of v1.9.4.
William
PS, the change is very minor; I attach the source code diffs from v1.9.4.
X-Sun-Data-Type: default
X-Sun-Data-Name: diffs
X-Sun-Content-Lines: 51
Index: Version
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/Version,v
retrieving revision 1.3
retrieving revision 1.4
diff -r1.3 -r1.4
1c1
< 1.9.4
> 1.9.5
Index: seqCom.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/seqCom.h,v
retrieving revision 1.2
diff -r1.2 -r1.3
33c33
< #define MAGIC 960811 /* current magic number for SPROG */
> #define MAGIC 000215 /* current magic number for SPROG */
Index: seq_task.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/seq/src/seq_task.c,v
diff -r1.2 -r1.3
35a36
> 15feb00,wfl Fixed problem (introduced by wfl) with sequencer deletion.
484,489c485
< /* Owing to persistent problems with ca_import() and ca_import_cancel(),
< temporarily suppress them altogether (WFL, 13-Oct-97) */
< #if 0
< /* Cancel the CA context for each state set task (have to re-import
< the context each time because ca_import_cancel() deletes the
< ca_static task variable) */
> /* Cancel the CA context for each state set task */
492,493d487
< extern int seqAuxTaskId;
498,503d491
< logMsg(" ca_import(0x%x)\n", seqAuxTaskId, 0,0,0,0,0);
< #endif /*DEBUG_CLEANUP*/
< SEVCHK (ca_import(seqAuxTaskId),
< "seq_cleanup:ca_import() failed")
< #ifdef DEBUG_CLEANUP
509d496
< #endif
Re: Improving S/N on tech-talk Maren Purves
Re: IOC Errors when StripTool is Running Christopher A. Larrieu
<2000>
2025
2026
RE: Improving S/N on tech-talk Christopher A. Larrieu
Greenspring Octal serial IP question john sinclair
<2000>
2025
2026
