Garrett,
I had a similar problem; a misbehaving CAMAC link would mess up the mv177
IOC record scan while waiting for a response from the link. To avoid this I
modified (LANL/CEBAF camacLib.c revised 03-12-96 by mlr) the 2992 driver
code. In summary, the link timeout was shortened from about 1 second per
CNAF to about 120 ms for slot-30 write CNAFS, and to twice the link
propogation time for non-slot-30 CNAFS.
For a hardware solution, Jorway Corporation makes a Model 176 Serial Byte
Highway Bypass module. We use these to automatically bypass powered-down
crate-groups to keep the main highway working. Perhaps you can use one of
these to bypass the 750 keV section of the link when the generator is turned
off.
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
----- Original Message -----
To: <[email protected]>
Sent: Wednesday, February 16, 2000 3:30 PM
Subject: camac crate init
> I've got a kind of a peculiar Camac here. I'm wondering if any of you
> can help me out.
> The Camac is driven by the Hytec 2992 (driver from CEBAF/TJNAF). I'm
> using EPICS_3.13.0b11 on an MV172.
> The crate sits in a very nasty (electrically) environment and goes
> "brain-dead" every once in a while. To get around this, I just execute
> the "camacCrateInit" routine from a subroutine record every ten
> seconds. This works very well, generally. Unfortunately, the crate is
> run off a generator ('cus it's in a room that floats at 750keV) and
> it's shut down when the machine is not running. The only problem there
> is that it brings the VME crate to its knees waiting to hear from the
> Camac and, as a result of repeated failed attempts to init the crate,
> eventually crashes. (Note that the mv167 was much more rhobust about
> this than the mv172, but both crash from it.)
> My questions to all of you are:
> 1) Is there a better way to do this?
> 2) What is that better way?
> Thanks very much in advance.
> Garrett Rinehart
> Intense Pulsed Neutron Source
> Argonne National Laboratory
> 9700 S. Cass Ave
> Argonne, IL 60439
> (630)252-6561
- camac crate init Garrett D. Rinehart
Re: camac crate init Andrew Johnson
Anyone using/supporting e2sr? Brian Bevins
<2000>
2025
2026
<2000>
2025
2026
