"Porter, Rodney" wrote:
> Following up on your security talk at APS, I was wondering if there is a
> standard way to disable telnet and rlogin. If not could one be made?
Probably the simplest way is to add the following two lines to your
startup script:
td tTelnetd
td tRlogind
On my mv167 this frees up about 21k of RAM from the two task stacks which
loginUserDelete doesn't do, and I guess it will also be marginally more
secure.
> These functions are not currently defined independently (as INCLUDE_RLOGIN
> and INCLUDE_TELNET), but are included with the definition
> INCLUDE_CONFIGURATION_5_2 in target/config/all/configAll.h, which is
> expanded in target/src/config/usrDepend.c.
You could replace that INCLUDE_CONFIGURATION_5_2 with the individual
expansions in your configAll.h if you want to change this and save even
more space by not loading the rlogind & telnetd code at all. I may do
this for the Tornado 2.0 BSPs, although the old method still works in that
version.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: disabling telnet and rlogin Steve Lewis
- disabling telnet and rlogin Porter, Rodney
<2000>
2025
2026
<2000>
2025
2026
