We're using R3.13.1. I looked in iocinf.c at line 1479. Here's the function. The messages I
reported are coming out while I'm trying to connect a channel. Eventually the connect request times
out. Why does the server want to free resources associated with a client connection?
void cac_close_ioc (IIU *piiu)
caAddrNode *pNode;
ciu chix;
int status;
unsigned chanDisconnectCount;
* dont close twice
assert (piiu->sock_chan!=INVALID_SOCKET);
LOCK;
ellDelete (&iiuList, &piiu->node);
* attempt to clear out messages in recv queue
(*piiu->procInput) (piiu);
if (piiu == piiuCast) {
piiuCast = NULL;
chanDisconnectCount = 0u;
else {
ciu pNext;
chanDisconnectCount = ellCount(&piiu->chidlist);
* remove IOC from the beacon hash table
pNode = (caAddrNode *) piiu->destAddr.node.next;
assert (pNode);
removeBeaconInetAddr (&pNode->destAddr.in);
chix = (ciu) ellFirst(&piiu->chidlist);
while (chix) {
pNext = (ciu) ellNext(&chix->node);
cacDisconnectChannel (chix);
chix = pNext;
if (fd_register_func) {
(*fd_register_func) ((void *)fd_register_arg, piiu->sock_chan, F
ALSE);
status = socket_close (piiu->sock_chan);
assert (status == 0);
* free message body cache
if (piiu->pCurData) {
free (piiu->pCurData);
piiu->pCurData = NULL;
piiu->curDataMax = 0;
piiu->sock_chan = INVALID_SOCKET;
if (chanDisconnectCount) {
1479 ==> genLocalExcep (ECA_DISCONN, piiu->host_name_str);
free (piiu);
UNLOCK;
Here's what I see. chanDisconnectCount is non-zero.
if (piiu == piiuCast) { <====== piiu is not equal to piiuCast other wise
piiuCast = NULL;
chanDisconnectCount gets set here.
ellCount returns the number of nodes that are found in a list.
So there are still nodes in the list. Why should this be an error?
Jeff Hill wrote:
> Geoff,
> The second part of the message which is varying between "No such file or directory",
> and "Address already in use" is generated directly from the socket library errno
> in the client process. These messages directly map to socket library error numbers
> 2 and 48 respectively. Sometimes there are problems because CA has accessed
> some other function in the C run time library in-between the spot in the source
> code where the problem occurred and where CA reports the error, and therefore
> the errno variable might be overwritten. In this situation I don't see this mechanism
> in play. Without knowing more about which operating system you are running on or
> what version of EPICS is running it is difficult to comment further.
> Jeff
> PS: I have attached the source code that is involved.
> status = connect(
> piiu->sock_chan,
> &pNode->destAddr.sa,
> sizeof(pNode->destAddr.sa));
> if (status == 0) {
> break;
> errnoCpy = SOCKERRNO;
> if (errnoCpy==SOCK_EISCONN) {
> * called connect after we are already connected
> * (this appears to be how they provide
> * connect completion notification)
> break;
> else if (
> errnoCpy==SOCK_EINPROGRESS ||
> errnoCpy==SOCK_EWOULDBLOCK /* for WINSOCK */
> * The socket is non-blocking and a
> * connection attempt has been initiated,
> * but not completed.
> UNLOCK;
> return;
> else if (errnoCpy==SOCK_EALREADY) {
> UNLOCK;
> return;
> #ifdef _WIN32
> * including this with vxWorks appears to
> * cause trouble
> else if (errnoCpy==SOCK_EINVAL) { /* a SOCK_EALREADY alias used by early WINSOCK */
> UNLOCK;
> return;
> #endif
> else if(errnoCpy==SOCK_EINTR) {
> * restart the system call if interrupted
> continue;
> else {
> TAG_CONN_DOWN(piiu);
> UNLOCK;
> ca_printf(
> "CAC: Unable to connect port %d on \"%s\" because %d=\"%s\"\n",
> ntohs(pNode->destAddr.in.sin_port),
> piiu->host_name_str, errnoCpy,
> SOCKERRSTR);
> return;
> > -----Original Message-----
> > From: [email protected] [mailto:[email protected]]
> > Sent: Tuesday, February 22, 2000 12:51 PM
> > To: tech-talk
> > Subject: CA error #2 and #48
> > Hi,
> > Would someone please explain when CA feels it should spit out these
> > error messages.
> > CAC: Unable to connect port 5064 on "d0olctl03.fnal.gov:5064" because
> > 2="No such file or directory"
> > CA.Client.Diagnostic..............................................
> > Message: "Network connection lost"
> > Severity: "Warning" Context: "d0olctl03.fnal.gov:5064"
> > Source File: ../iocinf.c Line Number: 1479
> > 48="Address already in use"
> > Thanks
> > Geoff
- RE: CA error #2 and #48 Jeff Hill
Re: Problems with messages... Pete R. Jemian
Re: Problems with messages... Steve Lewis
<2000>
2025
2026
<2000>
2025
2026
