1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mv162 hangs on reboot
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Mon, 06 Mar 2000 08:02:20 -0700
Marty,
I don't believe anything I am loading is calling rebootHookAdd although
upgrading drivers is probably a good thing. The IOC in question is
actualy running a combination of EPICS and code from the original FNAL
development effort here at the SDSS. Looks like the driver I am calling
originates from the Svedberg Accelerator Facility in Upsalla, circa
1994.
Marty Kraimer wrote:
> I suspect the following:
> 1) You are calling rebootHookAdd
> 2) Your reboot hookroutine turns off interrupts but does not do anything to stop
> new write requests directed to ipOctalSerial
> 3) Something else also is using rebootHookAdd and it's reboot hook routine does
> something like taskdelay.
> 4) A new write request is directed to the ipOctal and started.
> 5) The taskdelay completes and the reboot occurs. But that ipOctal comes up with
> transmit enabled.
> As I recall you started with the Hideos driver for ipOctalSerial. So did MPF. In
> MPF we found this problem. You may want to compare your version against the
> latest MPF version, which can be obtained from:
> http://www.aps.anl.gov/asd/people/mrk/epics/modules/serial/mpfSerial/
> At the very least you can look at the code for handling soft reboots.
> Marty Kraimer
	Peregrine
Peregrine M. McGehee, LANL Telescope Engineering, Sloan Digital Sky
Survey
(505) 667-3273, MS H820, Los Alamos National Laboratory, Los Alamos, NM
87545
mv162 hangs on reboot Peregrine M. McGehee
Re: mv162 hangs on reboot Marty Kraimer
Prev: Re: mv162 hangs on reboot Marty Kraimer
Next: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Perry L. Anthony
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mv162 hangs on reboot Garrett D. Rinehart
