Subject: |
Re: Problem with MVME162 and A24/D32 or D16 access to SIAM |
"Burkhard W. Kolb" <[email protected]> |
To: |
tech-talk Mailing List <[email protected]> |
Date: |
Mon, 06 Mar 2000 16:58:19 +0100 |
SUMMARY:
On the MVME162 the VME standard access is done via the second I/O map decoder,
not through one of the programmable map decoders. So it is necessary to disable
the second I/O map decoder and then enabled the second programmable map decoder.
In sysLib.c original version:
temp = *VMECHIP2_LBTVCR & 0xffff0fff;
*VMECHIP2_LBTVCR = temp |
LBTVCR_I2SUP |
LBTVCR_I2DATA |
LBTVCR_I2EN;
change to
*VMECHIP2_LBTVCR = temp; /* disable io map decoder 2 */
and then add
*VMECHIP2_LBSAR2 = 0xf0fff000; /* start and end address */
*VMECHIP2_LBSAR &= ~LBSAR2_D16; /* no D16 as default */
*VMECHIP2_LBSAR |= LBSAR2_AM_STD_USR_DATA |
LBSAR2_D32; /* but allow D32 */
*VMECHIP2_LBTVCR |= LBTVCR_EN2; /* enable second programmable
map decoder */
replace the following 2 lines
/* make sure map 2-4 is disabled */
*VMECHIP2_LBTVCR &= ~(LBTVCR_EN2 | LBTVCR_EN3 | LBTVCR_EN4);
with
/* make sure map 3-4 is disabled */
*VMECHIP2_LBTVCR &= ~(LBTVCR_EN3 | LBTVCR_EN4);
- Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Perry L. Anthony
The Future of vxWorks/Tornado Andrew Johnson
<2000>
2025
2026
Re: Problem with MVME162 and A24/D32 or D16 access to SIAM saa
<2000>
2025
2026
