1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: INP field for generic GPIB record
To: [email protected]
Cc: [email protected]
Date: Thu, 16 Mar 2000 11:31:55 -0600 (CST)
> Dear Ned Arnold
> 	Maybe this should have gone to the list, but the answer is
> probably pretty obvious.
> > Old style drivers have the starting address, interrupt vectors,
> > max number of cards, etc stored in include/module_types.h .
> I want to use a bunch of XYCOM XVME-240's in a single crate.  The limit on
> the number of these modules, as specified in include/module_types.h, is 2.
> If I want to increase that to 10, is it just a matter of changing the
> value to 10 in include/module_types.h and recompiling?
> 					thanks for any help,
> 								Steve Pate
You could do it that way, but everytime you get a new EPICS release you
would have to remember to change it.
The scheme that is recommended to change items defined in module_types.h is :
1) Copy the file base/drv/old/module_types.c to your application area src
   directory.
2) Edit module_types.c to delete things you don't want to change and edit
   those that you do.
3) Add module_types.o into your xxxAppLib (Makefile.Vx)
4) In the startup file, after the "ld < xxxAppLib", exceute the function
   module_types.  e.g.
cd appbin     (example is for 3.13.2)
ld < iocCore
ld < seq
ld < xxxAppLib
module_types
This will over-write the default values before the drivers begin their
initialization.
	Ned
Prev: Re: IOC Performance numbers Marty Kraimer
Next: Re: INP field for generic GPIB record Allan Honey
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: INP field for generic GPIB record Ned Arnold
