1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: compiler bug in unpatched Solaris C++ 5.0
To: [email protected]
Cc: [email protected]
Date: Tue, 21 Mar 2000 18:05:28 -0700 (MST)
Last night Jeff and I discovered a compiler bug  in the version of
Solaris C++ 5.0 that we had installed here.  The compiler had all the
files in /opt/SUNWspro/SC5.0/bin dated Dec. 15, 1998. and reported it's version as:
CC: WorkShop Compilers 5.0 98/12/15 C++ 5.0
I found the problem when I tried to delete clients of a portable channel access
server  and succeeded in causing the server itself to exit with various
messages suggesting that I contact Jeff Hill about internal errors in
the channel access server.  Jeff then traced the problem down to an error
in the code generated for an inline constructor.
The object code was not initializing the object to an argument passed in
as the source code specified.  The problem only occurred when
epics was compiled with optimization on.
This morning I tried compiling the same version of epics
 on one of the solaris machines at Argonne which had a compiler
 which also reported:
 but had several newer files in /opt/SUNWspro/SC5.0/bin
 dating to January 11th of this year and a few in May and September of 1999.
 The problem did not occur when EPICS was compiled with this "patched" version
 of the compiler. Our system manager installed the compiler patches here
 this afternoon, so we no longer have this problem.
 This message is to warn other people who might be using the unpatched version
 of this compiler.
 Rozelle Wright
 [email protected]
Re: compiler bug in unpatched Solaris C++ 5.0, Visual C++ Kay Kasemir
Prev: Problems with loadgif in edd/dm version 2.4 Noel Giffin
Next: RE: CA question (caRepeater) Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: compiler bug in unpatched Solaris C++ 5.0, Visual C++ Kay Kasemir
