1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM widgets
To: "Pierre MATTEI" <[email protected]>
Cc: <[email protected]>
Date: Wed, 29 Mar 2000 11:29:03 +0200 (CEST)
>>>>> "Isabelle" == Pierre MATTEI <[email protected]> writes:
  > I'm Isabelle YAO and I work for the CEA-Saclay.
  > I use EPICS R3.13.0.beta11, with a SOLARIS workstation.
  > I'm in charge of the design of a vacuum synoptic using MEDM
  > 2.3.5a.
  > I would like to know if vacuum objects, like pumps, gauges,
  > valves, already exist.
  > Another question : is it possible to upgrade the library of
  > MEDM by creating new objects (like magnets, DCCT, or
  > insertion devices like Faraday cup, profilers, ...) ?
I don't know if MEDM 2.3.5 is able to do what you want, but I'd like to
mention, that dm2k (the "european" version of MEDM, formerly named MEDM 2.4,
MEDM/DESY...) provides such a feature.
In dm2k, there is sth. called "Dynamic Symbol" which enables you to have a
library (i.e. another adl-file) of more or less complex groups of objects.
At runtime dm2k picks the object to display depending on the value of a PV,
so it may even change the displayed object at runtime.
Using this, you can easily compose a set of objects representing open or
closed valves, pumps... in a single adl-file and reuse these objects in any
adl-file you create.
To make sharing of these libraries easier, I'd volunteer to add an area to
the dm2k homepage to make those symbol-libraries available to others. Just
send me your adl-files and the corresponding part of the graphic rules.
The current version of dm2k is 2.5.1 and is available at
          http://www-csr.bessy.de/control/SoftDist/dm2k/
2.5.2 is currently undergoing some final tests and will be released soon.
This version will then also support cdev instead of channel access (thanks
to J.Chen @ JLab)!
Thomas Birke
__________________________________________________________________________
 /homas Birke                                  [email protected]
Berliner Elektronenspeicherringesellschaft für Synchrotronstrahlung m.b.H.
BESSY                                               Tel: +49 30 6392 4934
Albert Einstein Straße 15                           Fax: +49 30 6392 4859
12489 Berlin
Germany
MEDM widgets Pierre MATTEI
Prev: MEDM widgets Pierre MATTEI
Next: CA Server disconnects Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM widgets Ken Evans
