1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ATC40 & R3.13.1
To: "Dmitrovskiy Alexei" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Wed, 5 Apr 2000 09:20:15 -0600
Hello Alexei,
Perhaps this crash occurs because the object code is not, by default,
optimized in your beta11 build and it is in your R3.13.1 build. Be careful to use
the "volatile" keyword to declare structures that overlay hardware (or pointers
to registers). I will send a copy of the source code that we use for ATC40
support here if you are interested. As I recall there were some subtleties related
to getting the interrupt support correct.
Jeff
> -----Original Message-----
> From: Dmitrovskiy Alexei [mailto:[email protected]]
> Sent: Wednesday, April 05, 2000 3:11 AM
> To: [email protected]
> Subject: ATC40 & R3.13.1
> Hello,
> I use ATC40 PC ISA board as a carrier for IP modules. The OS is vxWorks. The
> original software (a new EPICS record, corresponding record and device
> supports, a hardware driver) was written for EPICS 3.13 beta11 and it works
> under this version without problems.
> My IP module has two interrupts. The peculiarity of interrupt usage is that
> it is necessary to write a zero (disable) followed by a one (enable) to
> INTERRUPT_EN register to generate a low to high transition for other pending
> IP interrupts after the current interrupt service routine is exited.
> So the problem is the following:
> - when I port my code to final EPICS release (3.13.1) and run it on PC, I
> get a crash during the first interrupt appearance even without any
> diagnostic message (but it works with MVME162);
> - if throw writing 0 (disable) to INT_EN register out of the ISR, no chances
> to process second interrupt, but there is no crash;
> - if I download everything from final EPICS release EXCEPT driver (the code
> is absolutely the same) which I take from beta 11, it works!
> A note: a driver object file from beta11 is about five times bigger than one
> from 3.13.1 (the same code and compiler). This is not usual for other
> architectures (for example, mv162/cc68k).
> Could anyone explain this behaviour? Thanks in advance.
> Alexei.
ATC40 & R3.13.1 Dmitrovskiy Alexei
Prev: ATC40 & R3.13.1 Dmitrovskiy Alexei
Next: Compiling extensions Dennis M. Reichhold
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
