Hi -
I am trying to force a binary output record to come up in a
specific state at IOC initialization. The device is an XVME-240, and I
want the outputs to come up "high" at startup. Here is what I tried:
record (bo,"mybo"){
field(PINI,"1")
field(VAL,"1")
field(SCAN,"Passive")
field(DTYP,"XY240_BO")
field(OUT,"#C0 S24")
field(ZNAM,"0")
field(ONAM,"1")
I set PINI to "1" to force processing at iocInit time, and I set the VAL
field to "1" to get the output to start out "high". But this doesn't
work -- the output comes up "low" at startup.
I also tried to use the DOL field:
record (bo,"mybo"){
field(PINI, "1")
field(DOL, "1")
field(SCAN, "Passive")
field(DTYP, "XY240_BO")
field(OUT, "#C0 S24")
field(ZNAM, "0")
field(ONAM, "1")
But that didn't work either.
I also tried this last setup without setting PINI at all. No cigar.
I am using EPICS Version R3.13.0.beta.11.
Quoting from the EPICS Record Reference Manual, Ch. 8 Binary Output,
Section 8 Record Support Routines:
"If DOL is a constant, then VAL is initialized to 1 if its value is
nonzero or initialized to 0 if DOL is zero, and UDF is set to FALSE."
I also read quite a bit of the tech-talk archive, especially two recent
threads about "VxWorks global variable device support" and "support for
output records" which discussed in some detail concerning what happens
to output records at startup. But somehow I am still missing something.
So what am I doing wrong?
thanks,
Steve Pate
Stephen Pate Department of Physics office: 505-646-2135
Box 30001, Dept. 3D dept: 505-646-3831
New Mexico State University fax: 505-646-1934
[email protected] Las Cruces NM 88003 home: 505-382-6880
- Re: forcing binary output value at initialization Andrew Johnson
- Re: forcing binary output value at initialization pate
serial device support john sinclair
<2000>
2025
2026
<2000>
2025
2026
