...and yes, at Keck we do have a modified version of the Xy240 driver that
uses a configuration routine as suggested by Andrew J. Its signature is:
void xy240Configure(
int cardNum, /* card number as used in INP fields */
void *base, /* base address of the board */
int vectorNum, /* interrupt vector number. If 0 then one */
/* will be found */
int itrLevel, /* board's interrupt level */
int itrState, /* whether or not interrupts should be */
/* enabled at init time specified as the */
/* mask for the 8 interrupt signals */
int scanState, /* whether or not the input scan task */
/* should be spawned at init time */
int portConfig, /* specifies port i/o direction */
/* configuration */
int presetFlag, /* specified whether or not output ports */
/* should be preset on init */
int presetValues
Allan Honey (the sender of the previous message) is the one to contact for
further information. We should get our local EPICS web site in order, plus
make sure that our drivers etc. are on the "EPICS supported hardware" list
(not all are).
The device support does not seem to honor readback of initial values, i.e.
the "return 0 to request rval -> val conversion" protocol. Presumably
this behavior could be controlled by another argument to the configuration
routine and/or some extra bits in the "presetFlag" argument.
William
Re: forcing binary output value at initialization Allan Honey
Slow booting IOCs Geoff Savage
<2000>
2025
2026
mpfGpib Marty Kraimer
<2000>
2025
2026
