1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbbo record
To: [email protected]
Date: Thu, 15 Jun 2000 16:23:52 +0200 (MET DST)
I  use a mbbo record to write a value from 0 to 255 to a binary input/output
device. In this record the state value fields ZRVL through FFVL are all
defaulted to 0  and the state string fields ZRST through FFST are all
empty string. So, the SDEF field is initialized to 0.
When I want to write a value greater than 15 with dbpf, the value is written
in the record but I get the following message:
-> dbpf "testmbbo","100"
DBR_STRING:          Illegal Value
value = 0 = 0x0
-> dbgf "testmbbo"
value = 0 = 0x0
The problem is the same with unix applications like caput, caget, medm, probe...
For instance :
sigs34(1)% probe &
enum type.
textAdjustCallback : Bad value!
sigs34(2)% caget "testmbbo"
testmbbo                       Illegal Value
This is my record
-> dbtr "testmbbo"
ACKS: NO_ALARM      ACKT: YES           ASG:                BKPT: 0x00
COSV: NO_ALARM      DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DOL:CONSTANT        DTYP: ICV196
EIST:               EISV: NO_ALARM      EIVL: 0x0           ELST:
ELSV: NO_ALARM      ELVL: 0x0           EVNT: 0             FFST:
FFSV: NO_ALARM      FFVL: 0x0           FLNK:CONSTANT 0     FRST:
FRSV: NO_ALARM      FRVL: 0x0           FTST:               FTSV: NO_ALARM
FTVL: 0x0           FVST:               FVSV: NO_ALARM      FVVL: 0x0
IVOA: Continue normally                 IVOV: 0             LALM: 255
LCNT: 0             MASK: 255           MLST: 255           NAME: testmbbo
NIST:               NISV: NO_ALARM      NIVL: 0x0           NOBT: 8
NSEV: NO_ALARM      NSTA: NO_ALARM      OMSL: supervisory   ONST:
ONSV: NO_ALARM      ONVL: 0x0           ORAW: 255           ORBV: 255
OUT:VME_IO #C0 S64 @                    PACT: 0             PHAS: 0
PINI: NO            PRIO: LOW           PROC: 0             PUTF: 0
RBV: 255            RPRO: 0             RVAL: 255           SCAN: Passive
SDEF: 0             SDIS:CONSTANT       SEVR: NO_ALARM      SHFT: 0
SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
STAT: NO_ALARM      SVST:               SVSV: NO_ALARM      SVVL: 0x0
SXST:               SXSV: NO_ALARM      SXVL: 0x0           TEST:
TESV: NO_ALARM      TEVL: 0x0           THST:               THSV: NO_ALARM
THVL: 0x0           TPRO: 0             TSE: 0              TSEL:CONSTANT
TTST:               TTSV: NO_ALARM      TTVL: 0x0           TVST:
TVSV: NO_ALARM      TVVL: 0x0           TWST:               TWSV: NO_ALARM
TWVL: 0x0           UDF: 0              UNSV: NO_ALARM      VAL: 255
ZRST:               ZRSV: NO_ALARM      ZRVL: 0x0
value = 0 = 0x0
I couldn't find this problem in tech-talk.
I use R3.13.1
Thanks in advance,
Francoise GOUGNAUD
CEA SACLAY
FRANCE
Re: mbbo record Ralph . Lange
Prev: Re: Proposed R3.13.3 Brian Bevins
Next: PID records [was Re: Proposed R3.13.3] Brian Bevins
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: signoff Min Tan
Next: Re: mbbo record Ralph . Lange
