1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems with the CA lib under LynxOS with R3.13.2
To: [email protected]
Date: Thu, 06 Jul 2000 14:41:13 +0200
Hello out there,
I hope this is not a to trivial Problem to commit to this mailing list,
but I am trying to make a caServer for LynxOS to control VME Cards
sharing the Crate with a PowerPC CPU under LynxOS. This works pretty
fine when I am using nearly all the options for Linux (LynxOS also uses
the gcc compiler).
But now I am trying to implement some CA queries into the server to get
some parameters from another server. Therefore I used the little example
'myClient' (as I used 'myServer' for the Server tasks), and this
compiles pretty fine but gets no connection to the Parameter Server
while the same code compiled with Linux does exactly what I expected it
to do.
The error messages are
CA.Client.Diagnostic..............................................
    Message: "The search request/beacon address list was empty after
initialization"
    Severity: Warning
    Source File: ../iocinf.c Line Number: 772
bin/LynxOS/daq_seb_cas<warning>: Cannot switch to asyncronous mode:
Error number not set
bin/LynxOS/daq_seb_cas<    err>: Do not receive value of
HAD:PARAM:HERAKLES:CRATE_ID: Error number not set
pretty similar to the ones ca_test supplied:
initialization"
    Severity: Warning
Not Found HAD:PARAM:HERAKLES:CRATE_ID
I made some minor changes to the sources in the base/src/ca tree because
LynxOS needs another way to find out it's own IP-address. Here's an
extract of the function I supplied:
> #ifdef LynxOS
> #include <stdio.h>
> #include <string.h>
> #include <sys/utsname.h>
> #include <netdb.h>
> char *getIfAddr(char *ip) {
>       struct utsname nameS, *name = &nameS;
>       struct hostent entryS, *entry = &entryS;
>       unsigned char first, second, third, fourth;
>       uname(name);
>       entry = gethostbyname(name->nodename);
>       first = *(entry->h_addr);
>       second = *((entry->h_addr) + 1);
>       third = *((entry->h_addr) + 2);
>       fourth = *((entry->h_addr) + 3);
>       sprintf(ip,"%d.%d.%d.%d", first, second, third, fourth);
>       return ip;
> #endif
62a86
>       char                            myownifaddr[16];
94c118,123
< #ifndef LynxOS
> #ifdef LynxOS
>       getIfAddr(myownifaddr);
>       init = TRUE;
>       addr.sin_family = AF_INET;
>       addr.sin_addr.s_addr = inet_addr(myownifaddr);
> #else
144,148d172
< #endif
I am using Version R3.13.2 of the EPICS base package.
Is anybody out there who has experience with the CA client lib under
LynxOS.
Thank You for any comments
Benjamin
Benjamin Sailer
eMail: [email protected]
Sodann sollst Du zaehlen bis zur Drei. Drei soll die Zahl sein,
bis zu der Du zaehlst, und die Zahl, bis zu der Du zaehlst, soll
die Drei sein. Weder sollst Du zaehlen bis zur Vier, noch sollst
Du zaehlen nur bis zur Zwei, es sei denn, Du faehrst fort zu
zaehlen bis zur Drei. Die Fuenf scheidet voellig aus.
RE: Problems with the CA lib under LynxOS with R3.13.2 Jeff Hill
Prev: RE: Interrupts Jeff Hill
Next: RE: Problems with the CA lib under LynxOS with R3.13.2 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PID records Mark Rivers
