1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access Diagnostic Message (Tornado II and R3.13.3)
To: "Ernest Williams" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Mon, 21 Aug 2000 14:11:07 -0600
Hi Earnest,
Thanks for the heads up. This is the first I have heard about this.
I don't see anything obvious in the R3.13.3 CA client source code
that might be causing this. It would be interesting to know if
this occurs at other sites, and in particular if this occurs when
EPICS is not running on Tornado II.
Jeff
> -----Original Message-----
> From: Ernest Williams [mailto:[email protected]]
> Sent: Monday, August 21, 2000 1:36 PM
> To: '[email protected]'
> Subject: Channel Access Errors
> Hi Jeff,
> Occasionally, I get channel access errors under Tornado 2.0.
> Have you encountered something similar?  Here is my error message:
> CAC: Unable to connect port 5064 on "164.54.156.31:5064" because
> 22="S_errno_EINVAL"
> CA.Client.Diagnostic..............................................
>     Message: "Network connection lost"
>     Severity: "Warning" Context: "164.54.156.31:5064"
>     Source File: ../iocinf.c Line Number: 1488
> The above message occurs on IOC: 164.54.156.37
> I am running EPICS RELEASE R3.13.3  ---- Tornado 2.0 ---- Target = mv162
> ---- Host = Solaris--SPARC
> Thanks,
> Ernest L. Williams Jr.
> Beamline Controls and Computer Systems Engineer
> MHATT-CAT, Sector 7
> Advanced Photon Source
> Office: (630) 252-0273
> Lab: (630) 252-0209
> Fax: (630) 252-0279
> email: [email protected]
Prev: Re: EPICS support for Galil motor controllers Graham Waters
Next: bug Chip Watson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS support for Galil motor controllers???? Leonard J. Reder
