New releases of the Message Passing Facility and the serial support for MPF are
now available.The changes are:
MPF Release 1-6
The config files have been changed to use the base 3.13.3 makeBaseApp rules.
This method also works for earlier release ofbase.
Stack Overflow may occur for PowerPC. This problem was fixed by changing the
stack size in the calls to taskSpawn in the following files: RMRClient.cc,
RMRServer.cc, andTcp.cc.
DevMpf previously issued an error message and returned without calling startIO
if PACT is true and no replyMessage is present. This check is no longer made.
This allows the creation of device support that has to process several messages
before a record completes processing.
mpfSerial Release 1-2
The interrupt routine was modified so that it works correctly when the IP
modules uses separate interrupts for read and write.
The config files were changed to use the base 3.13.3 rules. It now builds
properly for 3.13.3 as well as previous releases of base.
Doc and tar files are available at:
http://www.aps.anl.gov/asd/people/mrk/epics/modules/bus/mpf/
Re: intConnect vs ipmIntConnect vs devConnectInterrupt Bernd Schoeneburg
Re: Let's use the STL! [Was: about the abstractData.h] Bob Dalesio
<2000>
2025
2026
address change for Phase Three Logic Chong Lee
Let's use the STL! [Was: about the abstractData.h] Benjamin Franksen
<2000>
2025
2026
