1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: socket creation errors
To: "'[email protected]'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 10 Oct 2000 18:32:01 -0500
This error:
> interrupt
> eio: reset
> I have seen references to "interrupt, eio: reset" in tech-talk"
> whatever causes that message seems to be benign.
I have seen this error in 2 circumstances, and only on MVME167 CPUs under
vxWorks 5.4 and EPICS R3.13.3.
1) Right after iocInit.  In that case it seems to be benign, as you suggest.
2) After several hours of intense communication with some non-TCP/IP
Ethernet modules, using etherInputHookAdd. In that case the error is
serious, the IOC cannot communicate on the network at all, although there is
no other indication from the vxWorks console that anything is amiss.  This
problem is an active case with WRS for me now.
The software which is running when we get this failure is basically
unchanged from software which works fine under vxWorks 5.3 and EPICS
R3.13.1.1.
Mark Rivers
Prev: socket creation errors Graham Waters
Next: RE: socket creation errors Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: socket creation errors Graham Waters
Next: Keithley 7002/2010 data aquisition Mathew Rippa
