Gaspare,
You do NOT need to rebuild the entire EPICS release to relocate
VME base addresses.
What must be done is that the default base address specifications in
module_types.h must be redefined AFTER loading iocCore but BEFORE
iocInit. There is a file in base (src/drv/old/module_types.c) which
one can use as a template for overriding default parameters in module_types.h.
For your example, create a simple program in your application area
(e.g. hardwareConfig.c) as follows :
#include <vxWorks.h>
#include <types.h>
#include <dbDefs.h>
#include <dbAccess.h>
#include <types.h>
#include <module_types.h>
hardwareConfig()
NIGPIB_SHORT_OFF = 0x8000; /* Relocate NI-1014 to 0x8000 */
NIGPIB_IVEC_BASE = 100;
NIGPIB_IRQ_LEVEL = 5;
return(0);
Then, in your startup script for the ioc, do the following ...
cd topbin
ld < iocCore
ld < myLib
ld < hardwareConfig.o
# change hardware configuration.
hardwareConfig
iocInit
Peruse module_types.c to see what other things can be overridden (e.g. # of
cards, interrupt vectors, etc)
Hope this helps ...
Ned
> Hello,
> I am an EPICS user, and I have to change the base address of my NI1014
> module in a crowded VME crate. It is actually set to 0x5000. How do I
> change this setting in software, which files do I have to edit (other
> than base/include/module_types.h) ?
> Do I have to recompile the all EPICS or can I do something simpler ?
> Many other users using the same state machine (and same EPICS core) work
> with NI1014, but not having overpopulation problems in their crates they
> do not have (want) to change their base address. Do I have a better
> chance other than having my own complete, private version of EPICS ?
> My EPICS version is 3.12.2 and I am using the driver drvGpib.c
> in its 1991 version by John Winans.
> Thank you very much for any insight you can give.
> Gaspare Lo Curto
> ### Gaspare Lo Curto office 234 | Telephone: + 49 89 32354226 ###
> ### Max Planck Institut fur Physik | Fax: + 49 89 3226704 ###
> ### Foehringer Ring 6 |
> ### D-80805 Munich GERMANY | ###
devSupport for CAEN V767 Peter Mueller
Interrupts, vectors and mv230x ioc Timo Korhonen
<2000>
2025
2026
changing base address to NI1014-GPIB Gaspare Lo Curto
<2000>
2025
2026
