Hi guys, I have make the epics base and installed the Motif( which is
needed when making medm) under the help of Markus from SLS. now when
making medm, I come across the errors like this:
gcc: language sb not recognized
gcc: ../xgif.c: linker input file unused since linking not done
gcc -pedantic -o medm -g -xsb -DSCIPLOT -DMOTIF -DEDITRES
-DMEDM_HELP_PATH="\"http://www.
aps.anl.gov/asd/controls/epics/EpicsDocumentation/ExtensionsManuals/MEDM\""
-D_X86_ -Dlinux
-DUNIX -I. -I.. -I../../printUtils -I../../xc -I/usr/X11R6/include
-I/usr/X11R6/include/X11 -I../../../../include
-I../../../../include/os/Linux -I../../../../../extensions/include -I.
./../../../../base/include -I../../../../../base/include/os/Linux
-L../../../../../base
/lib/Linux/ -L../../../../lib/Linux/ -L/usr/X11R6/lib/
medmCartesianPlot.o medmSciPlot.o S
ciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o
channelPalette.o colorPale
tte.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o
medmByte.o medmChoiceButton
s.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o
medmIndicator.o medm
Menu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o
medmPixmap.o medmPolygon.o me
dmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o
medmStripChart.o medmTex
t.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWidget.o
objectPalette.o productDescr
iptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o
xgif.o -lANLwidgets-lPrintUtils -lca -lCom -lXm -lXt -lXp -lXmu
-lX11 -lm
gcc: medmCartesianPlot.o: No such file or directory
gcc: medmSciPlot.o: No such file or directory
gcc: SciPlot.o: No such file or directory
gcc: medmCA.o: No such file or directory
gcc: actions.o: No such file or directory
gcc: bubbleHelp.o: No such file or directory
gcc: callbacks.o: No such file or directory
gcc: browserHelp.o: No such file or directory
gcc: channelPalette.o: No such file or directory
gcc: colorPalette.o: No such file or directory
gcc: display.o: No such file or directory
gcc: eventHandlers.o: No such file or directory
gcc: help.o: No such file or directory
gcc: medm.o: No such file or directory
gcc: medmArc.o: No such file or directory
gcc: medmBar.o: No such file or directory
gcc: medmByte.o: No such file or directory
gcc: medmChoiceButtons.o: No such file or directory
gcc: medmCommon.o: No such file or directory
gcc: medmPixmap.o: No such file or directory
gcc: medmPolygon.o: No such file or directory
gcc: medmPolyline.o: No such file or directory
gcc: medmRectangle.o: No such file or directory
gcc: medmRelatedDisplay.o: No such file or directory
gcc: medmShellCommand.o: No such file or directory
gcc: medmStripChart.o: No such file or directory
gcc: medmText.o: No such file or directory
gcc: medmTextEntry.o: No such file or directory
gcc: medmTextUpdate.o: No such file or directory
gcc: medmValuator.o: No such file or directory
gcc: medmWidget.o: No such file or directory
gcc: objectPalette.o: No such file or directory
gcc: productDescriptionShell.o: No such file or directory
gcc: resourcePalette.o: No such file or directory
gcc: updateMonitors.o: No such file or directory
gcc: updateTask.o: No such file or directory
gcc: utils.o: No such file or directory
gcc: xgif.o: No such file or directory
make[3]: *** [medm] Error 1
make[3]: Leaving directory
`/usr/local/epics/extensions/bin/medmbeta/medm/O.Linux'
make[2]: *** [medm] Error 2
make[2]: Leaving directory
make[1]: *** [buildInstall.Linux] Error 2
make[1]: Leaving directory
`/usr/local/epics/extensions/bin/medmbeta/medm'
make: *** [medm.buildInstall] Error 2
These *.o file can all be found under
/usr/local/epics/extensions/bin/medmbeta/medm/O.solaris, but none in
..../O.Linux ( does that mean this version of medm is only for
solaris? the version is medmbeta2.3.6)
It seems I should set the HOSTARCH somewhere. when making the epics
base, I have set the /usr/local/epics/base/config/CONFIG_SITE for the
Linux enviroment, but for the extensions installation,
Should I do some setting in /usr/local/epics/extensions/config ?
Thank you very much for your help.
BTW: If you reply this mail, please kindly send a copy to my private
mailbox, so I can read the mail as soon as possible)
Cheng Weixing (from SSRF)
- Re: Help for Install MEDM on Redhat6.2 Robert Soliday
Debian Gnu g++ problem Burkhard W. Kolb
<2000>
2025
2026
Re: Debian Gnu g++ problem Thomas Fechner
<2000>
2025
2026
