1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks login authentication
To: Steven Hartman <[email protected]>
Cc: [email protected]
Date: Wed, 01 Nov 2000 12:50:23 -0600
Steven Hartman wrote:
> The system is an MVME167, vxWorks 5.4, kernel 2.5, tornado 2. VxWorks was
> built with INCLUDE_SECURITY defined, and I specified in configAll.h a
> LOGIN_USER_NAME and a LOGIN_PASSWORD (generated with vxencrypt on a
> solaris 7 host). I have confirmed that rlogind and telnetd are running on
> the ioc.
> Connnecting via a console port to the crate works fine and everything
> appears to be functioning correctly.
> However, telnet or rlogin to the crate results in "Login Incorrect" using
> the specified user name, passwd pair.
Are you sure you're using the right version of vxencrypt for your vxWorks
image?  I seem to remember that WRS changed the password encryption
recently, maybe in a patch file, because it wasn't making use of the first
character or something like that.  Should you be using a version of
vxencrypt from a different tornado release then you'll see the problems
you're getting.  Do a which vxencrypt and/or use an explicit pathname to
the tornado version that you're booting and see if you get a different
encrypted string.
- Andrew
Every great idea appears crazy to start with.
VxWorks login authentication Steven Hartman
Prev: VxWorks login authentication Steven Hartman
Next: Re: VxWorks login authentication Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
