1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxStats
To: Paul Sichta <[email protected]>
Cc: [email protected]
Date: Tue, 21 Nov 2000 09:49:31 -0600
Paul Sichta wrote:
> 1)  I thought VXStats was part of 'base',  but there is a similarly-named
> entry (vxStats) in the Soft Support list.  [ Andrew, we *now* know we must
> only use the Soft Support list's links to get software.... but there is no
> link or contact shown for vxStats  :-)   ].  Is there a difference in the
> device support ?
There is an unbundled version for 3.14 in CVS that doesn't have a web page
yet; Marty or I will create a suitable page when we can find time).  For
earlier releases it should be present in base, so use that version (the
3.14 one has a 'configure' directory instead of 'config' so isn't
backwards compatible).
> 2)  I think I need a low priority cpuUsageTask to run on my IOC.  How do I
> get the source for this?
The vxStats device support provides this for you.  There are usage
instructions in the comments at the beginning of the devVXStats.c source
file, including example database entries.
- Andrew
Every great idea appears crazy to start with.
vxStats Paul Sichta
Prev: Re: Record size offset... Andrew Johnson
Next: epics base 3.14.0alpha1 Updated Documentation Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxStats Steve Lewis
