Eric,
My understanding from the release notes is that R3.14 has been
tested on Redhat x86 IOCs. Who did this work?
In any case we are just starting our dresign and trade studies
work - the real construction effort with the exception of support
for an adaptive optics & interferometry testbed won't start for
anothe year. Even the real testbed controls don't need to around
until the spring of 2001.
In response to your question about devices - we are starting with
a simple RS-232 based command and response system. Many of our
collaborators are familiar with Linux so that's our first choice
for starters but we certainly won't use it for the harder real-time
systems.
Aloha,
Peregrine
Eric Norum wrote:
> The CLS (my previous employer) is using Linux and R3.14, however Linux
> is limited to the software development machines and the OPIs. RTEMS is
> used on the IOCs. I do know that the example IOC application runs on
> Linux, though. Many extensions (MEDM, DM2K, SDDS, Ezca, ca-tcl) are
> running just fine on R3.14/Linux.
> What devices will you be accessing from your Linux IOCs? I know that
> the LAN/GPIB driver won't work on Linux because the RPC library on Linux
> is not thread-safe.
> If it's just a hardware issue that's causing you to look at Linux for
> your IOCs you may be interested to know that I've run the R3.14 example
> IOC application on RTEMS on a PC-clone.
Peregrine M. McGehee [email protected] (505) 667-3273
LANL Telescope Engineering, Sloan Digital Sky Survey
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- R3.14 iocCore/Linux Peregrine M. McGehee
- Re: R3.14 iocCore/Linux Eric Norum
Re: R3.14 iocCore/Linux John Munro
<2000>
2025
2026
<2000>
2025
2026
