1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: HP E2050A LanGpib gateway driver
To: [email protected]
Date: Fri, 8 Dec 2000 13:23:15 -1000
Hello.
Has anybody experienced problems with the LanGpib driver from Benjamin Franksen
(any version) returning the wrong ioc address? I have consulted Peter Mueller
(from Bessy) on this. It looks like a bug in the call to
"get_myaddress(&iocAddr)".
The driver returns only 128.171.0.0 when our actual address is 128.171.90.150
.. As a result it incorrectly thinks our gateway is 128.171.0.59,  which is
actually 128.171.90.59 .  Verbose details below...
Thanks for any help.
~Mathew Rippa
	 Joint Astronomy Centre
With ibDebug =4 ...
dbLoadDatabase "scsTaq-0.1/dbd/K2010.dbd"
value = 0 = 0x0
dbLoadRecords("scsTaq-0.1/data/K2010Example.db", "host=059, i3eAddr=16")
value = 0 = 0x0
iocLogDisable=1
_iocLogDisable = 0x6fd378: value = 1 = 0x1
iocInit "scsTaq-0.1/data/resource.def"
###  @(#)EPICS IOC CORE
###  @(#)Version R3.13.0.beta.11 $$Date: 1997/07/14 14:04:12 $$
initIb(): network address = 128.171.0.0
drvLanGpib (release 2.4.b) initialized successfully
initXx dealing with record >K2010:05916< device >devXxK2010Gpib<
devXxK2010Gpib() allocating a hwpvt structure for link 59 device 16
issuing IBGENLINK ioctl for link 59
ioctlIb(5, 59, -1, 8, 16, 0x0): called
ibFindLink(59): returning 0x0
ibLinkInit(0x7189d0): called, type 5, link 59, bug -1
ibLinkStart(0x7189d0): called for linkType 5, link 59
ibLinkTask(0x7189d0): started for link type 5, link 59
ibGenLink(0x7189d0): called
hpGenLink(0x7189d0): called
hpGenLink(0x7189d0): ip address of RPC server: 128.171.0.59
hpGenLink(0x7189d0): can't connect to gateway
ibGenLink(0x7189d0): init failed for link type 5, link 59
ibLinkDisable(0x7189d0): called for linkType 5, link 59
ioctlIb(5, 59, -1, 8, 16, 0x0): linkTask init failure / timeout
task: 0X797d9c tShell
No device at specified address L59, A16, init_record(K2010:05916)
initXx dealing with record >K2010:05916autoZero< device >devXxK2010Gpib<
ioctlIb(5, 59, -1, 9, -1, 0x7188a0): called
No device at specified address L59 A16 init_record(K2010:05916autoZero)
initXx dealing with record >K2010:05916sdc< device >devXxK2010Gpib<
ioctlIb(5, 59, -1, 9, -1, 0x718828): called
No device at specified address L59 A16 init_record(K2010:05916sdc)
initXx dealing with record >K2010:05916function< device >devXxK2010Gpib<
ioctlIb(5, 59, -1, 9, -1, 0x794f9c): called
No device at specified address L59 A16 init_record(K2010:05916function)
initXx dealing with record >K2010:05916ping< device >devXxK2010Gpib<
ioctlIb(5, 59, -1, 9, -1, 0x794f40): called
No device at specified address L59 A16 init_record(K2010:05916ping)
initXx dealing with record >K2010:05916init< device >devXxK2010Gpib<
ioctlIb(5, 59, -1, 9, -1, 0x794ee4): called
No device at specified address L59 A16 init_record(K2010:05916init)
value = 0 = 0x0
Re: HP E2050A LanGpib gateway driver Andrew Johnson
Prev: Re: C++ API backwards compatibility Chris Larrieu
Next: Re: HP E2050A LanGpib gateway driver Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
