1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CONFIG_ARCH mv162/mv167
To: [email protected]
Date: Mon, 18 Dec 2000 10:41:59 -1000
Dear all,
In the default config distributions, there are two distinct CONFIG_ARCH
for the mv167 and the mv162.
We have an application using both these targets and realized much code
was probably compiled twice (starting wiht the EPICS core) when there
was no need for it, the diffent flags beeing specifc to the 68040 CPU
rather than the actual boards.
I had to build a whole system, and just realised how much time would be
saved this way. the only issue being some ./bin/mv167 references in my
mv162 startup script (or vice versa)..
My question is: would it make sense (and be safe) to declare a generic
CONFIG_ARCH.68040 ? that would let me clean up the startup script issue.
  Matthieu
Matthieu Bec              Gemini Observatory
Tel: +1 808 9742557       670 N. A'ohoku Place
Fax: +1 808 9359235       Hilo, Hawaii 96720, USA
Re: CONFIG_ARCH mv162/mv167 Marty Kraimer
Re: CONFIG_ARCH mv162/mv167 Andrew Johnson
Prev: Re: base release 3.13.4 Steven Hartman
Next: Re: CONFIG_ARCH mv162/mv167 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: interp and mbbi/o-direct Kevin Tsubota
