One thing you should do is to make sure that ~p3/library/epics appears
in the symbol search path. To do this:
Start Capfast.
>From the menubar, select Options->Search Path->Show Search Path.
The search path will be displayed at the bottom of the window. If
~p3/library/epics does not appear in the search path, you can add it
with Options->Search Path->Add Directory to Beginning.
I hope that helps.
--Brian Bevins
Accelerator Controls Group
Jefferson Lab
shen guobao wrote:
> Hello,
> Recently we have purchased the Capfast3.10.2 from Phase 3.
> After I finished install, I cant find the "epics" directrory in the
> ~p3/library
> and some relative mnu file in ~p3/wcs/lib/menus/new. As the
> "cf-epics-configure.txt"
> file,I should get the library and menus from other EPICS members.
> But I have downloaded the "epicsRecSym.tar.gz" and "menus.EPICS.tar.gz"
> from Phase3
> ftp server. In I made the "epics" directory, and decompress the
> "epicsRecSym.tar.gz" file in "epics" the "menus.EPICS.tar.gz" in
> ~p3/wcs/lib/menus.new.
> After that, I type "xschedit&" in my sh(Bourne Shell), all things seem
> ok.
> But when I select Part->EPICS Library(small)->analog in, it gives the
> following error:
> searching for file...done
> Can't read file 'eais': No such file or directrry
> But in ~p3/library/epics, "eais.sym" is there.
> How can I do? Any answer is welcome and appreciated.
> Thanks.
> shen guobao
> Shanghai Synchrotron Radiation Center
> 2000/12/21
- Re: How to configure the Capfast? shen guobao
- How to configure the Capfast? shen guobao
PMC and PC-MIP configuration for PowerPC Ernest L. Williams Jr.
<2000>
2025
2026
<2000>
2025
2026
