> > Here is a little 'hack' that might be of use to you ...
> Hey, that's neat!
> Flink the sub record to a stringin that points back to the sub's DESC
> field and you can easily run a camonitor to see who is putting values in
> that record ... soft access spying.
> Ralph
No need for the stringin record, the subroutine posts a monitor on the
.DESC field. One can monitor that directly.
One limitation is the 28 character field. In fact, I now see that the
code doesn't even check for an overrun, so if you have a long user name
and long client name, you will probably overwrite memory. :(
I said it was a hack!
A more thorough and robust solution is left as an exercise for the student.
Ned
- Re: process passive task Ian Smith
Re: process passive task Ralph Lange
<2001>
2025
2026
<2001>
2025
2026
