1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gdd/dbMapper.cc
To: [email protected]
Date: Wed, 07 Feb 2001 12:32:34 +0100
Hi all,
the VMS-Compiler complained about an array overflow in gdd/dbMapper.cc (EPICS
R3.13.3).
line 1094: (function: mapGraphicGddToEnum() )
	strncpy(&(db->strs[i][0]),str[i].fixed_string,
		sizeof(aitFixedString));
	db->strs[i][sizeof(aitFixedString)-1u] = '\0';
db is of type dbr_gr_enum with db->strs[MAX_ENUM_STATES][MAX_ENUM_STRING_SIZE]
with MAX_ENUM_STATES = 16 and MAX_ENUM_STRING_SIZE = 26
aitFixedString is a char array of size AIT_FIXED_STRING_SIZE, which is defined
to be 40.
So strncpy may copy up to 40 characters into a char-array with length 26, which
could corrupt memory (especially if the enum array is filled up with 16
entries).
Same problem at line: 1117 (function: mapControlGddToEnum() )
Better is the following:
	strncpy(...,...,MAX_ENUM_STRING_SIZE);
	db->strs[i][MAX_ENUM_STRING_SIZE-1u] = '\0';
Jens
Prev: RE: UDP error Jeff Hill
Next: EPICS runtime problems on Motorola mv162-P242E CPUs Dave Barker
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
