1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS runtime problems on Motorola mv162-P242E CPUs
To: Jeff Hill <[email protected]>
Cc: [email protected], EPICS-tech-talk <[email protected]>
Date: Wed, 07 Feb 2001 16:33:36 -1000
This rings a bell.
I made some stupid programming mistake that under certain circumstances
caused the CPU to be 100% busy. The console serial line was the only
way in to find out (dm windows stayed blank/white because there was
no CPU time left. It appeared dead).
As far as I remember this was on vxWorks 5.3.1 and some earlier
EPICS 3.13 though.
Maren
Jeff Hill wrote:
> Don't assume that the IOC is 100% dead before you connect
> a terminal to the serial port and try to get console
> access w/o depending on the network. Sometimes the IP kernel
> will be dead but vxWorks is still running. Console serial
> access via a terminal can prove to be invaluable when
> debugging vxWorks problems.
> > -----Original Message-----
> > From: [email protected]
> > We are having run time problems running EPICS on the new Motorola MV162
> > P242E cards. I am running VxWorks 5.2, and have tried EPICS R3.12.2 and
> > R3.13.3. In all cases the CPU freezes or locks up, usually within 24
> > hours. We think it crashes more quickly if sequencers are running.
> > Has anyone else had problems running EPICS on these cards?
> > I'm in the process of seeing if we require a BSP upgrade from Wind River
> > (we may have to upgrade to tornado in order to get the latest BSPs)
RE: EPICS runtime problems on Motorola mv162-P242E CPUs Jeff Hill
Prev: RE: EPICS runtime problems on Motorola mv162-P242E CPUs Jeff Hill
Next: Re: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
