1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [Fwd: dm won't load gif]
To: <[email protected]>
Cc: "Ken Evans" <[email protected]>
Date: Tue, 13 Feb 2001 16:28:22 -0600
Ian,
     Your file doesn't seem to use any GIF89a features.  You can probably
fix it simply by changing the GIF ID text, GIF89a, to GIF87a in the first 6
bytes of the file.  DM is only checking that ID when it prints the message
you mentioned.  It shouldn't hurt anything, even if it doesn't work.  (I did
that and will forward it you to separately.)
     If you need to do this again, and the above doesn't work, there is an
EPICS extension, SGA, that manipulates GIF files.  It doesn't save as
GIF87a, but if you eliminate all the non-image blocks, save it, and then
change the first 6 bytes as above, it may work.
	-Ken
-------- Original Message --------
Subject: dm won't load gif
Date: Tue, 13 Feb 2001 10:25:37 -1000 (HST)
To: [email protected]
I can't get dm to load a gif image.  I get the error message: loadGIF: not
a GIF file.  I've tried it with monochrome and 256 colour versions and
passed it through xv to no avail.  The image is attached.
Help!
TIA
Ian A Smith					Telephone: (808) 961 3756
Joint Astronomy Centre				Fax:       (808) 961 6516
660 N. A'ohoku Place					   (808) 969 6591
University Park					Web: http://www.jach.hawaii.edu
Hilo
Hawaii
96720
Prev: RE: dm won't load gif Chestnut, Ronald P.
Next: Wavetek Model 39 device support ? Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dm won't load gif Kenneth Evans, Jr.
