> Hello-
> I have a database using the sequence record. There are times when
> one of the delays can be quite long (DLY2 = 10 minutes).
> grecord(seq,"$(P)XRA_seq") {
> field(DO1,"1")
> field(LNK1,"$(P)$(DIO)$(N2).VAL PP NMS")
> field(DLY2,".01")
> field(DO2,"1")
> field(LNK2,"$(P)$(DIO)$(N3).VAL PP NMS")
> If a user makes a mistake and wants to restart the process, the time he/she
> needs to wait for the record to finish processing can be too long. My
> question is, once the record is executed is there a way to stop the record
> from processing or reset it.
> Thanks
> Dr. Timothy Graber
I don't think you can clear or reset the delay. If this were a requirement,
I would probably use a simple sequencer program, which could be implemented
to provide the reset/clear.
OR, if you are into tricky databases, you could use a calcout
record to do the delay and provide the reset capability. Something like
this ... (no guarantees)
field(DO1,"1")
field(DO2,"10")
field(LNK2,"delayCALC.VAL CA NMS")
grecord(calcout,"delayCALC") {
field(SCAN,"1 second")
field(INPA,"delayCALC.VAL NPP NMS")
field(INPB,"-10")
field(CALC,"A<0?B:A>0?A-1:0")
field(OOPT,"Transition To Zero")
field(DOPT,"Use OCAL")
field(OCAL,"1")
field(OUT,"$(P)$(DIO)$(N3).VAL PP NMS")
Theory of operation ...
$(P)XRA_seq.DO2 is the delay value (in scan times of delayCALC). When LNK2
is executed, it loads the delay value into delayCALC.VAL (I'm not sure
if the CA flag is necessary). When delayCALC scans, it decrements .VAL.
When .VAL goes from 1 to 0, the result of OCAL (1) is written to
the OUT link. delayCALC.VAL remains 0 until the sequence record preloads
it again.
To reset/clear the delay without processing the OUT link, write a negative
number to delayCALC.VAL, which will remain negative until preloaded again.
Since the .VAL field never went to 0, the OUT link will not process.
NOT TESTED !!!!!
Ned
Delays in seq records Ralph Lange
Callbacks and the PCAS question. Brian Tieman
<2001>
2025
2026
<2001>
2025
2026
