Paul,
Paul Sichta wrote:
> We've just built EPICS 3.13.2 under Solaris 8, without errors. Unlike out
> R3.13.beta11 release, we do not see the vxWorks and vxWorks.sym files in the
> ~base/bin/mv177 directory. makeBaseApp.pl does not populate our
> <top>/iocBoot/iocxxx directory with the vxWorks and vxWorks.sym either
> (presumably because they are not in base). ca_test works fine as well as an
> example application from the new build.
Ever since we realized that the object files installed in the bin
directory don't actually depend on the BSP (only on the CPU type, so mv162
and mv167 binaries are identical) we've stopped installing the boot files
into base and the application directories. Here at APS we use many mv162
boards but now tell EPICS that they're mv167s, the only difference being
the boot file (an mv162lc is a different CPU though).
> Is it now S.O.P. to boot operational IOC's from the vxWorks files that are
> in the ~vw/tornado101 subdirectory, and not those under <top> ? Did we
> forget a 'switch' in the build?
It is T.R.O.P (The Recommended Operating Practice), although you have to
manually ensure that the IOC is booting from the same version of Tornado
(1.0.1, 2.0 etc.) that the software was built for (usually not a problem).
- Andrew
Every great idea appears crazy to start with.
- Re: where to load vxWorks.sym Ralph Lange
- where to load vxWorks.sym Paul Sichta
Re: Callbacks and the PCAS question. Brian Tieman
<2001>
2025
2026
<2001>
2025
2026
