1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.13.4 Build
To: [email protected]
Date: Thu, 8 Mar 2001 09:17:27 -1000 (HST)
I must be the only person that does this but....
When building EPICS I keep the installation tree and the source code tree
separate. For R3.13.4 I did this by redefining INSTALL_LOCATION_BASE in
CONFIG_SITE to be the install location I wanted.
The problem was that there is a bug when installing the configuration
files because of all the .PHONY definitions in CONFIG_BASE. I believe
these are there to speed up the build, but they also mean that a number of
the configuration files do not get installed.
I suggest either:
1. Removing the .PHONY declarations or
2. putting them in an ifndef MAKE_CONFIG_DIR block, and only defining
   MAKE_CONFIG_DIR in the Makefile.Host in the config directory.
I did the latter.
Nick Rees
Joint Astronomy Centre               Ph:       +1 (808) 961-3756
660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
Hilo, HI.  96720                     Internet: [email protected]
Prev: Re: Fortran CA Client Interface Andrew Johnson
Next: RE: R3.13.4 Build Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS meeting at PSI - agenda development Bob Dalesio
