1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm handler causes excas to core dump
To: "Chris Timossi" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 21 Mar 2001 17:21:46 -0600 (CST)
  > I've built a cas application starting with the excas example.
  > The cas application core dumps when I run the alarm handler against it.
  > It looks like the server library is trying to call a callback that doesnt
  > exist but I cant tell. I just get the following stack trace:
  > Anyone have experience running the alarm handler with the portable server ?
Depending on how you use the alarm handler, it might try to acknowledge
alarms using Channel Access' special DBR types.
The GDD library that server tools use does not support application types
that correspond to the alarm acknowledgement CA messages.
The EPICS CA Proxy Gateway is the only CAS tool I know that supports
alarm operations. It is based on patches to the GDD and CAS libraries
that are not part of EPICS base. This is a non-desirable situation
created outside of my resonsibility that has been around for some years
now.
If you really, really want to see what is needed, you will have to fetch
the Gateway code, take a deep breath and look at it. (The Gateway has a
Tar file of the changes to EPICS base needed to do the ALH awareness.)
Hope this helps...
Ralph
ps. There's a link to the Gateway stuff on the EPICS Doc pages.
alarm handler causes excas to core dump Chris Timossi
Prev: alarm handler causes excas to core dump Chris Timossi
Next: RE: alarm handler causes excas to core dump Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
