PS> When I use Solaris CDE, the medm (display) windows do not have
PS> corner resizing brackets. The only way to resize is to
PS> right-mouse along the window's title-bar and choose the 'Size'
PS> option, then drag the mouse around to get the new window
PS> size. Other x-clients (e.g. alh, StripTool, terminal) have the
PS> corner brackets.
This behavior is hard coded into MEDM and was there before I
inherited it. I don't know the reason. Probably because resizing
didn't work at the time. It looks to me like it should be changed.
PS> Is there an 'X-switch' or CDE environment setting which I can set
PS> to make the medm windows show the corner resize brackets?
I don't think so. You could change the code and rebuild. These
are the lines in display.c. (Looks like I had already flagged it ;-)
/* Turn resize handles off
* KE: Is is really good to do this? */
XtSetArg(args[nargs],XmNmwmDecorations,MWM_DECOR_ALL|MWM_DECOR_RESIZEH);
nargs++;
-Ken
EPICS .db to PostgreSQL RDB Noboru Yamamoto
Re: Motor record, servo motors & OMS58 Jens Eden (PTB)
<2001>
2025
2026
medm window resizing Paul Sichta
<2001>
2025
2026
