At Keck we have a driver for the XYCOM XVME 540 12 bit analog I/O board,
which uses interrupts. I can provide that as an example if you want.
ftp ftp.keck.hawaii.edu
login as anonymous
cd outgoing
cd epics
cd drivers
cd xy540 (you need to use 'ls' and not 'dir')
cheers,
Allan
> From [email protected] Tue Apr 10 22:08:04 2001
> From: "Weixing Cheng" <[email protected]>
> To: <[email protected]>
> Subject: Interrupt Epics Driver
> Date: Wed, 11 Apr 2001 16:07:42 +0800
> MIME-Version: 1.0
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-Mailer: Microsoft Outlook Express 5.00.2615.200
> X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2615.200
> Content-Transfer-Encoding: 8bit
> X-MIME-Autoconverted: from base64 to 8bit by keck.hawaii.edu id WAA08676
> Hello, everyone:
> I have developed the epics driver for AcromagAVME9321, which is a 12 bit AD card.it was working under the continuous mode. Now I want to use the interrupt mode, what should I deal with the driver code and .db file ? Thank you for your suggestion.
> Cheng Weixing
Interrupt Epics Driver Weixing Cheng
Re: CA clients on vxWorks Matthieu Bec
<2001>
2025
2026
CA on MacOS X Noboru Yamamoto
<2001>
2025
2026
